Zev0 Skin Folds & Creases- Oversize Tab image blocks controller label.
nowefgnowefg Posts: 557
The attachment showns the issue. For some reason, some Tab images or icons show up so large that they block the Name of the controller. It's a rather big hassle every time I want to use this product. Very inconvenient.
This is a problem with a number of other products, from other PA's, as well, not just Zev0, but their product clearly demnstrates it.
.Does anyone know what causes this? Short of support tickets, (because it's clearly a flaw,) is there a way to fix it, preferably without having to access each individual product slider in Shaping Tab
Shows up in 4.12 and earlier versions of DS.
  • NorthOf45NorthOf45 Posts: 5,741
    They use thumbnail images, as expected, but for them to display properly in the controllers (big and small), they must have a transparent margin. Compare those that do not overlap the controller name and you will see the difference. Follow the path indicated for the Card on the Parameter Settings dialog for a couple of them and preview the thumbnails. The image is resized to fit, but uses the entire field to display it, which includes, unfortunately, a range that includes the title area (on the large controllers) and the (-) sign and start of the name on the small controllers.
    How to fix it? Each offending thumbnail has to be edited. No way around that, I think. Be nice if that could be scripted or batch processed in the imaging editing s/w.
  • nowefgnowefg Posts: 557
    Interesting, thanks NorthOf45.
    I follow your description, but I think instead of the hassle of fixing these defective products myself, I'm going to report them via support ticket as a defective products.  Really, Zev0's been in the business long enough to know that if users can't read the name of the specific morph for a slider controller, there's a problem that should have been resolved before the product was offered for sale.
    I've tried to PM the artist, to make them aware, and they requested a screenshot, but for some reason, the image attached above here doesn't paste to a PM and there's no Attach link.
