so wait, hold the presses, morphs work by copying them from G3 to G8 data folders?
in The Commons
Is it true you can just copy some morphs from G3 to G8 and they work? Can someone give me a quickrun down on this? I have a lot more stuff for G3F G3M than G8. But just now getting some G8 stuff thanks to sales. But now I'm reading some stuff about using the same UVS and some things you can just copy from the data folder for G3 to the data folder for G8 etc... I don't want to screw anything up so would like to get some clarification first before I go tampering with stuff I know little about.
you can the genitalia ones with some notepad editing as the same mesh
not the others AFAIK
No. The mesh is different, that won't work.
ok, bummer. so projection morph type stuff, like to help fit with clothing won't work?
the encrypted HDmorphs will even work on the anatomical elements if you want that stuff
I cannot find the post about what to edit in notepad
it's mostly just copying and moving to data folders and editing paths some names for all the morphs in it and not in the encrypted file
I think I may have found what you're referring too...
https://www.daz3d.com/forums/discussion/comment/2778776/#Comment_2778776
This is great news for me being on a budget.
yes thanks because I was looking for it too again unsuccessfully
i can never find anything using the forum search, I had to search off-site with startpage to find that, lol
hey, so I'm still a litle confused on which things will work and which wont. Will something like wear-them-all for G3F G3M work with G8F G8M with some editing of files? Or is that a bridge to far?
The G3 and G8 mesh are different, so morph deltas for one won't work on the other, what Jepe is talking about is the male genitals, don't have them but it sounds like they are the same mesh, so morph assets can be copied between the two, you will need to do a bit of text editing before they will show up in DS though.
