global tween change?
tami_7956c1f21dtami_7956c1f21d Posts: 0
Is it possible to make a global change to all the tweens in an animation in Carrara? I can't seem to "select all" tweens, which would be the way to go, I'd think. I have too many tweens to select manually.
I know how to change the default tweener, but at this point, I have an animation already set up and I want to change all the tweens (to the same tweener) at this point.
Thanks in advance for help!
  • DartanbeckDartanbeck Posts: 21,959
    In this case, the best way that I know is to open all of your hierarchies in the sequencer and drag a selection around all of the tweeners at once. Right, there is no select all function for that.
