Epic wings expension
Heyo all!
I just came here because I got a little problem with a feature I bought recently
http://www.daz3d.com/epic-wings-x-pansion
to complete my epic wings.
Thing is:
When I try to use one of the prop i get the error message "can't locate file"
So I click on locate file, I navigate to the file, select it and poof, it work.
Then after some try I realized what was wrong: the shortcut, or whatever you want to call it, ask for a file name that is not the actual name of the needed file.
So I was wondering if there was a way to solve that problem for all the props at the same time or if I have to do a one by one?
Thanks all!
Post edited by FelinaLain on
Put in a support ticket so they can get it fixed. I don't have it so can't test it. Are you installing products with DIM or manually? Maybe try reinstalling it and see if it still does it. If so I'd say report it. It's a pretty easy fix and shouldn't take much time at all
What was the item? I'm not having any errors with this product. What version of DS are you using and did you install with DIM or manually? Are other items you installed this way working correctly?
I used the installer, but my computer did do something weird at the end of the install...
I'm going to try re-install it to see if it work
EDIT: after trying, yeah it seem somehow my installation went wrong. Now it all work fine
