Adding to Cart…
The only problem with moving entire categories is that it won't merge if you move it to the same place as a category with the same name. Other than that, you can move entire categories (with all their subcategories).
Yes, the files in the Support folder are only used to import the metadata -- once it's been imported, it stays even if you delete the Support folder. The only way to move it to Unassigned is to delete it from the current location.
No, but what you can do is what I do. Disable the auto-import of Metadata.
To do so, go to Edit > Preferences > Startup and Uncheck the metadata import page.
Then, when you do "Scan Known Directories for Files" off of the content tab context menu, you'll get all the data in the Unassigned category. Categorize as desired. Then you can do a metadata re-import and you'll both have default metadata and the categories you've manually created out of the Unassigned variety.
I wouldn't do it if I was you but if you really want everything in unassigned you just have to reset the Database then do what Adamr001 wrote
I tested a bit to create meta datas for things I made and categorize them. I find that task to be pretty much annoying but that's me. Good luck
