Render CPU _ GPU
maupiresferreiramaupiresferreira Posts: 3
edited May 2020 in New Users
good evening When I render using the iray engine if I select only the GPU (nvidia1060) does not render, however if I select the CPU and the GPU only the cpu renders the GPU at 0%. Can someone help me ? Thank you
good evening
When I render using the iray engine if I select only the GPU (nvidia1060) does not render, however if I select the CPU and the GPU only the cpu renders the GPU at 0%. Can someone help me ? Thank yougood evening
Post edited by Chohole on
  • fixmypcmikefixmypcmike Posts: 19,710
    Make sure your Nvidia driver is up-to-date
  • odasteinodastein Posts: 606
    Windows task manager is unreliable when it comes to GPU use. It will tell you that the GPU isn't used when it fact it is. At least with DAZ Studio, I don't know if it's a general problem or only a problem with DAZ.
