How to remove this effect from clothes?
MuzMelMuzMel Posts: 76
Ive no idea why this is happening. What setting should I adjust?
  • VisuimagVisuimag Posts: 578
    edited May 2020
    What's your Display Optimization looking like? Is it set to 'Best'? You should be able to press F2 and go to Interface and check!
    Post edited by Visuimag on
  • MuzMelMuzMel Posts: 76
    Ah thank you, Im on a Mac so no F2 sorry. This is only a issue on this costume, I applied Iray spandex shaders on it and then this happened.
  • Richard HaseltineRichard Haseltine Posts: 109,532
    Have you tried restarting Daz Studio?
  • Silas3DSilas3D Posts: 809
    I'm not sure theres anything you can do about this - it's essentially a Moiré effect, an optical illusion created by the density of the shader. I suspect it will do the same in viewport and render.
    Your options would be to zoom in or lower the scaling of the shader, which will minimise the effect.
  • vagansvagans Posts: 422
    Maybe it's a result of whatever lighting you're using.
    In my experience, moire patterns are usually created by normal or bump maps.
    Laurie
  • duckbombduckbomb Posts: 585
    I'd try reducing the vertical/horizontal tiling of the texture on that surface.
    I'd try a different shader. UV maps do matter and different shaders can/will produce different results.
  • ProtozoonProtozoon Posts: 554
    edited May 2020
    You could play with the pixel filter in the render tab. Gaussian 1.5 is the default and should produce quite soft results moire-wise. Have you tweaked that?
    https://www.daz3d.com/forums/discussion/390696/any-trick-s-to-reduce-moire-effect-in-renders#latest
    Post edited by Protozoon on
  • nicsttnicstt Posts: 11,715
    More info please; item; shader(s); even render settings.
    Share the duff file, if we have the items we can see what we get.
  • nonesuch00nonesuch00 Posts: 18,830
    It's just a moire pattern and you can only zoom out or zoom in until the pattern disappears.
  • richardandtracyrichardandtracy Posts: 7,513
    Or alternatively change the texture scale as opposed to zooming as it'll have the same effect.
  • FenixPhoenixFenixPhoenix Posts: 3,197
    Although this involves post-work, if you have photoshop you may find this short tutorial useful:
