[Solved]Eye Pupil Issue with G8 Male
[Solved] I searched using pupil instead of dilate, and found an answer
I am hoping someone else has seen this issue and knows a fix for it (I have also submitted a ticket to Tech Support).
When I load a base g8 male figure, the pupils of the eyes are different. One eye is normal while the other is about the size of a pin-prick. What would be causing this, and is there a way to fix it?
Thanks in advance
Post edited by shg0816_13461e8196 on
  • Richard HaseltineRichard Haseltine Posts: 109,082
    This is/was an issue with one of the characters from the Valentino 8 release -  make sure yiu aren't missing an update.
  • I figured it out. It's the Renshaw character pupil morph loading automatically dialed at 100%.
