Is there a way to quickly reset the Iray Uber shader?
If I've made a bunch of changes to the shader, and I just want to reset it back to its default values, is there a quick way to do this?
  • Noah LGPNoah LGP Posts: 2,617
    edited May 2020
    I apply dzDefault shader (Shaders / Other) and !Iray Uber Base shader (Shaders / Iray / Uber)
    Post edited by Noah LGP on
  • Those ThingsThose Things Posts: 1,147
    Unfortunately, this doesn't work. Any images I plugged into the image channels on the Uber shader remain when I apply the dzDefault shader.
  • xmasrosexmasrose Posts: 1,409
    edited May 2020
    I believe what you can do is load a primitive (cube for example) it will load with the iray basic metallicity/roughness shader without any image and save it as a shader. Then you can apply it to anything that has image textures and it will remove them. At least it does for me. Hope that helps.
    Post edited by xmasrose on
  • lilweeplilweep Posts: 2,753
    you mean copy/paste the surface properties?  that method would work although you'd think there should be a way to do this in a couple less clicks.
    lilweep Are you asking me?
    just posing a question to the general audience
  • fastbike1fastbike1 Posts: 4,079
    @Those Things "Any images I plugged into the image channels on the Uber shader remain"
    What about removing the image maps then applying the dzdefault?
  • Richard HaseltineRichard Haseltine Posts: 108,590
    Right, create a primitive with the desired render engine active, select it and its surface (click with Surface Seection too), save File>Save as>Shader Preset. To apply select the target object and its surface(s), then double-click.
    Ahhh, I gotcha. So, I'm just creating my own "reset" shader. You'd think there would be an easier route, but I'll give this a try. Thank you!
    Once you have the shader preset, right-click on it and select Create Custom Action - then you can have it immediately available in the Scripts menu.
  • RobinsonRobinson Posts: 751
    There's quite an easy way, yea.  Show the shader mixer window, click apply, then apply Daz Uber shader.  Done.
    Huh...that actually is a pretty decent workaround. Thanks!
