How to save the surface settings made by the geometry editor
The white stripes on these boots were made by adding them to the surface through geometry. But what should I do to save these white stripes, and then they can be used directly next time. I try to save as metrial present. But only Can save the texture of the boots. There is no way to save these white stripes. What should I do? Thank youThe white stripes on these boots were made by adding them to the surface through geometry. But what should I do to save these white stripes, and then they can be used directly next time. I try to save as metrial present. But only Can save the texture of the boots. There is no way to save these white stripes. What should I do? Thank youThe white stripes on these boots were made by adding them to the surface through geometry. But what should I do to save these white stripes, and then they can be used directly next time. I try to save as metrial present. But only Can save the texture of the boots. There is no way to save these white stripes. What should I do? Thank you
