mcjNewCastle - The long awaited final version of the Castle prop
124678
  • mCasualmCasual Posts: 4,607
    edited March 2014
    the blue ball is at the closest point on the yellow rod from the white ball
    that's how the fake stick-on wood sheets will be applied on the handrails and painting-frames
    function projectPointOnLine( a, b, p ){ //P' = A + {(AB • AP) / || AB ||²} AB AB = b.subtract( a ); AP = p.subtract( a ); lenab2 = AB.length(); lenab2 *= lenab2; t = AB.dot( AP ) / lenab2; AB.x *= t AB.y *= t AB.z *= t p3 = a.add( AB ) return( p3 );}
    1920 x 1080 - 229K
    1920 x 1080 - 187K
    Post edited by mCasual on
    edited March 2014
    good news is i untangled the uv map issues for ramp/frame generator
    mixed good-bad news is i spent time away from that project to improve Amy's wardrobe
    1920 x 1080 - 544K
    1920 x 1080 - 194K
    1920 x 1080 - 242K
    1920 x 1080 - 143K
    edited March 2014
    first acceptable results !
    meaning we're closer to having the handrail/painting-frames generator script
    meaning we're closer to having the staircase props and maybe staircase generator script
    then the castle !
    but i'll try to make the release of the castle as soon as i figured stairs options
    800 x 500 - 114K
    800 x 500 - 152K
    800 x 500 - 83K
  • Miss BMiss B Posts: 3,071
    Oh those frames look great. Very realistic looking. :coolsmile:
  • RAMWolffRAMWolff Posts: 10,343
    DANG dood! That's really awesome! Can't wait for this one!
    edited March 2014
    the 9 molding shapes that will come with the script
    you'll be able to use custom shapes made with mcjLathe or use any obj file as long as the vertices form a closed curve
    they are based on frames for Flat TVs found here http://www.flatscreenframing.com/?page_id=530
    maybe i should add some that are really for paintings
    1920 x 1200 - 1M
    1920 x 1200 - 1M
    1280 x 960 - 77K
    Wow, I never knew they had frames for flat screen TVs. Most folks I know who have flat screen TVs never seem to have them flat on the wall, or at least not the ones I've seen.
    Those are really nice frame designs though.
  • frank0314frank0314 Posts: 14,707
    We have 4 flat screens and none of them are on the wall. All are sitting on a dresser or entertainment center
    edited March 2014
    started turning the script into something usable by the non-me :)
    and Happy St-Patricks day!
    figure 2 -- there will be a graphical preview of the selected molding curve
    1421 x 792 - 145K
    1176 x 652 - 92K
    hand-rail or frame molding selection
    548 x 648 - 317K
    That's how I prefer them. One friend had this jumbo flat screen hanging on the living room wall, and I was always afraid the damn thing was going to fall down and crash on the credenza underneath it.
    They've since taken it down when they moved furniture around, so now it's sitting on the credenza instead.
    edited March 2014
    see how texture placement is simple
    600 x 600 - 50K
    1920 x 1080 - 3M
    Wanted to ask you... how did you manage to get the UV mapping to follow the frame around so perfectly??
    edited March 2014
    it was the main problem to solve
    remember earlier in the forum thread there was Amy holding a yellow stick and a ball was being projected on that wand
    as the script builds the UV map, it carries along a stick like that , it projects the vertices of the tube onto the stick
    this gives the V part of the UV coordinate -
    -- the easier to understand way, though less true is that i un-fold the frame then use the positions of the vertices as the uv map
    below you can see the uv map
    and the script settings that generated the 16x9 frame
    580 x 670 - 49K
    1024 x 51 - 7K
    1503 x 796 - 152K
    Very interesting. Always wanted a UV program that could map AROUND properly so fills would follow as expected.
    edited March 2014
    the textures are really wrapped around the frame, i meani t's not projected through
    and the UV map covers the whole length, so you could have a text that doesn't repeat printed on the frame
    though in this image i tiled the texture 2 x 50
    267 x 603 - 42K
    1920 x 1080 - 598K
    edited March 2014
    using bump map for detailed carvings
    fig 1 rendered in Blender bump map
    fig 2 rendered in Daz studio software render - chrome metal + displacement map
    fig 3 the bump make ( you can grab it, though it has little misalignments )
    512 x 512 - 22K
    1280 x 720 - 588K
    1920 x 1080 - 399K
    Very nice there. I tried posting an hour or so ago and kept getting redirected to My Account page. Stupid forums...
    edited March 2014
    maybe not (maybe so) related to this, recently i was often getting Chrome messages that it could not find web sites, or could not connect
    so today i change the DNS server my internet service uses, it's like a phone book, you say www.daz3d.com, the server answers " the IP is 122.122.121.121"
    i will use the google dns servers which are said to be very responsive
    the google dns servers are 8.8.8.8 and 8.8.4.4
    for windows7 the recipe to change the dns server ( i changed it for IPv4 because IPV6 refused the dns servers i was giving it ) )
    is here http://www.opennicproject.org/configure-your-dns/how-to-change-dns-servers-in-windows-7/
    the frame/handrail generator script will have 3 "bar edge" moldings
    my image composition skills at work **cough cough**
    1920 x 1080 - 365K
    Hmmm, but if I change my DNS then would I have to reconfigure all my wireless devices as well??
    it's linked to your PC only and its "adapter"
    well you'd do this only if Chrome gives you trouble
    in my case, when i navigate to a new web site
    chrome often says "unable to connect ....." or unable to find this site
    then i have to refresh the browser and it gets through
    it's as if the DNS servers i was using by default dont respond fast enough
    or Chrome just doesnt wait long enough for the answer
    Hmm, well I'm on Windows 8 and use Firefox.
    I did follow the link you provided and then the link on THAT page took me here:
    http://sourceforge.net/projects/opennicwizard/
    Apparently, if I'm reading this correctly, this is an automated way to do this... I think...
    edited March 2014
    simpler to change the dns server using the windows settings -- or even simpler to not change anything !
    the openNIC thing would add a program continuously running in the background , it looks more like a replacement for Windows's DNS services than an automated change-a-ma-thing
    708 x 512 - 76K
    1134 x 808 - 109K
    edited March 2014
    hard turns
    the ramp/frames/mouldings script will let you create 2 types of corners
    or 3
    1 hard - , a frame in this case is made of 4 non-welded tubes/sections
    2 soft - vertices at the corners are shared by 2 tube segments
    soft - the disadvantage is that some surfaces may appear gray in renders
    the advantage is that using subDivision you can obtain ovals
    hard - advantage is that you can smoothen the mouldings without changing the shape of the path
    so a square table will remain square but the mouldings will look extra smooth
    960 x 540 - 211K
    960 x 540 - 215K
    Very nice. This is going to be a very useful script!
    Ohhhh, the frames are looking great.
    @Richard, you should try the following with FireFox. Go to Tools > Options > Privacy > Show Cookies... and scroll down until you see the DAZ3D folder. Then delete the "frontend" cookie in that list. That should help for a while. I usually have to do this about once or twice a year.
    Thanks B. Yes, I saw Cho's post about that and immediately did that. Seems a bit better but I still hate hate hate having to log on all the time. That NEVER seems to get better!
    The new plan is to prioritize the release of a first beta version of the castle
    ( possible with the help of the handrails/frames builder script )
    that castle will come with fixed the stairs as seen recently
    then later, publish the frames/handrails script
    then publish modular staircase props
    and maybe another version of the castle which is easier to re-staicasify :)
    then we got to get back to physics and Amy's BMX stunts !
    1920 x 1080 - 370K
    i made new wigs (they call them ailerons ) for the lucarnes which in English is ...skylight ... see i didnt know this
    ( i thought skylights were pyramid shaped rooftop windows )
    1920 x 1080 - 436K
    "staicasify " HAHAHAHAHA...
    Looks good.
