[Released] Now-Crowd Billboards - Sailing the Seven Seas and Conquistadors
2»
  • faromobilfaromobil Posts: 21
    Bought both sets, but "Sailing the Seven Seas" won't install through DIM. Tried to delete pacage, re-download and install, but install stops at 64% each time. " Conquistadors" installed through DIM as a breeze.
    This is an issue that you need to report to Daz.  They handle all installation issues.
    (And thank you for your support smiley)
    I have the same problem, it seems that package nr. 14 is not complete.
  • RiverSoft ArtRiverSoft Art Posts: 6,784
    Unfortunately, there is nothing I can do.  Daz repackages the submission for downloads.  You need to submit a ticket.
    Hi,
     till today I got no answer from DAZ but I saw You found a solution with that other guy in this forum. I  have the same problem, in the folder Props/RiverSoft Art/NowCrowd-Billboards is only the folder Conquistadors and another I purchased before. Only in the folder runtime/textures/Riversoft Art/ Now-Crowd Billboards I can see Sailing the Seven Seas. Unfortunately I not really understand the solution that I got "Sailing the Seven Seas" in the folder Props too and the script from the package 01 can finish the installation. I am not a native speaker, may be my english is not good enough.
    Thank You for response
    Best regards
    Robert
  • fixmypcmikefixmypcmike Posts: 19,684
    faromobil said:
    Hi,
    Best regards
    Robert
    "Sailing the Seven Seas" has 14 zips.  The first one has all the folders that you see in Daz Studio, "Props/RiverSoft Art/NowCrowd-Billboards/Sailing the Seven Seas" and the Scripts.  The rest are all the textures.  Since the one bad file is in the first zip, that's the one that fails.  If you unzip that zip file manually to a temporary location, your unzipping program should ask you if you want to skip the bad file.  Skip it and let the rest of the files get unzipped.
    Now go to the temporary location.  There will be a folder called "Content".  Go inside that folder and there will be 4 folders:  Scripts, Data, Props, and Runtime.  Take those 4 folders and merge them into your content folder, e.g. "My Daz 3D Library".  That should solve the problem.  You'll only be missing the one bad file.
    Hi,
    I did in that way You told me but unfortunelaty it doesnt work. I controlled all folders and file from the content folder they are in the right folder in my libary.  Maybe the problem is that in the download folder I found beside the zip Folder a dsx.file with the same name too. Now I must give up, I stay in Thailand and it is allready 4:20 in the morning.
    Thank You for try to help me
    good morning
    Rob
    faromobil said:
    Hi,
    good morning
    Rob
    I wish they would update that zip file.  The dsx file is not the problem.  You need to make sure that you see something like this:
    • C:\Documents/My DAZ 3D Library/Props/RiverSoft Art/Now-Crowd Billboards/Sailing the Seven Seas/Cannon Gunner Billboard.duf
    • C:\Documents/My DAZ 3D Library/Props/RiverSoft Art/Now-Crowd Billboards/Sailing the Seven Seas/Cannon Gunner Billboard.png
    • C:\Documents/My DAZ 3D Library/Props/RiverSoft Art/Now-Crowd Billboards/Sailing the Seven Seas/Cannon Gunner Billboard.tip.png
    • C:\Documents/My DAZ 3D Library/Props/RiverSoft Art/Now-Crowd Billboards/Sailing the Seven Seas/Cannon Loader Billboard.duf
    • C:\Documents/My DAZ 3D Library/Props/RiverSoft Art/Now-Crowd Billboards/Sailing the Seven Seas/Cannon Loader Billboard.png
    • C:\Documents/My DAZ 3D Library/Props/RiverSoft Art/Now-Crowd Billboards/Sailing the Seven Seas/Cannon Loader Billboard.tip.png
    • C:\Documents/My DAZ 3D Library/Props/RiverSoft Art/Now-Crowd Billboards/Sailing the Seven Seas/Cannon Sponger Billboard.duf
    Thank you @Fixmypcmike for trying smiley
    Hi,
    I got good news, Amy from DAZ contact me in the meanwhile. They will check the problem. Maybe the path is also a problem, I buy so many things that most of my DAZ products are on external drives. I did in Your way and You can check in the attachment, that I do it well, also with the other folders and files in the unzipped contant folder.
    We will find a solution and by the way I like Your products and I know it is a lot of work!
    Thank You for everything
    Robert
    1920 x 1080 - 530K
    faromobil said:
    Hi,
    Robert
    Is Daz_3_Terra_Runtime also where your People, Environments, and Poses directories are?
    Yes, I installed also Your other products Now-Crowd Billboards - ConquistadorsNow-Crowd Billboards - Zombie ApocalypseNow-Crowd Billboards - Disaster! and Now-Crowd Utilities on the same drive and folder with DIM without any problems, many other people, environments, poses etc. too.
    Don`t care to much, we will find a solution, relax, its weekend ;)
    Many thanks!
    robert
    Many thanks!
    robert
    Hmmm.  More than likely, this Daz_3_Terra_Runtime is not in your path for Daz Studio Formats.
    The code does this:
    function IncludeFile( sRelativePath )
    // Get the content manager
    var oContentMgr = App.getContentMgr();
    // If we don't have a content manager
    if( !oContentMgr ){
    // We're done...
    return;
    // Declareworking variables
    var sPreferredBasePath, sAbsolutePath;
    // Get the path of this script
    var sScriptPath = getScriptFileName();
    // Define the directory type to look in
    var nDirType = DzContentMgr.AllDirs;
    // Also look in cloud directories
    nDirType = DzContentMgr.AllDirsAndCloud;
    //Define the preferred [mapped] base path; use the path of the current script
    sPreferredBasePath = oContentMgr.getMappedPath( nDirType, sScriptPath, false );
    // Get the absolute path of the file to be shown/opened
    sAbsolutePath = oContentMgr.getAbsolutePath( nDirType, sRelativePath, sPreferredBasePath );
    // If the file was found
    if( !sAbsolutePath.isEmpty() ){
    print('Found:', sAbsolutePath);
    return sAbsolutePath;
    // If the file was not found
    } else {
    // Inform the user
    MessageBox.information(
    qsTr("'%1' could not be found in a mapped content directory. " +
    "Check the installation and try again.").arg( sRelativePath ),
    qsTr("File Not Found"), qsTr("&Ok") );
    var dirBaseNC = "Props/RiverSoft Art/Now-Crowd Billboards/";
    IncludeFile(dirBaseNC);
    If I copy and paste that into the Script IDE, I get:
    Executing Script...
    ..\..\..\..\..\src\sdksource\general\dzcontentmgr.cpp(4083): Empty path passed to DzContentMgr::getMappedPath()
    Found: D:/Documents/DAZ 3D/Studio/My Library/Props/RiverSoft Art/Now-Crowd Billboards/
    Result: D:/Documents/DAZ 3D/Studio/My Library/Props/RiverSoft Art/Now-Crowd Billboards/
    Script executed in 0 secs 4 msecs.
    Hi, sorry for my late answer, I got sick this week :(
    Thank You very much for Your efforts to help me but this level is too high for me.
    Never change a running system, the way I do, cause I have not really experience to modify scripts in a database. In the meanwhile I have more than 4000 Products, this is the first time, that I got problem like this. I sent the infos You gave me before to Amy, she answer allready to give that infos to the technical support.
    I think thats the best way for You too, because they should also fix the problem with the broken .png file.
    At the moment I got feedback  from DAZ support I will send it to You too immediately.
    Best regards
    robert
    Best regards
    robert
    Ok, Robert.  Good luck!
    faromobil said:
    Hi!
    I want to inform You, that I found two update files in the DIM  for Your products Now-Crowd Billboards - Conquistadors and Now-Crowd Billboards - Sailing the Seven Seas yesterday.
    Everything works fine now smiley
    faromobil said:
    Excellent!  I am glad everything is working for you now.
    yes
