Map Master Pro makes UV if you have none?
at one point in the demo film.. it looks like he picks and object and the UVs are created
and then you can group them on a map?
my buildings now are basically shapes with shaders
so what I want it to convert the objects and their shaders to maps
The process is just foggy enough if my brain I can't decide whether to buy Map Master or not
regarding the building below..
at one point I was separate pieces
then I got it all down to one item with 4 or 5 surfaces I can apply textures too
but I can't quite figure out if I choose this in MMP I can get it to create a UV map
that make sense?
thanks
at 7 minutes in the bottom video it saves Build and Save  UV Templates.
I just can't tell if there have to be  pre-existing ones that are gather for a large one or not.
So I guess the question  really is Does this function as a UV mapper?
  • thd777thd777 Posts: 945
    No, it does not. It can produce images of the UV map, basically UV templates that you can include with the texture set. That's what it says in the video, too. I usually do the UV mapping while modelling.
    ciao
    TD
