morphs++ aren't working in Poser 7
Hi there. I'm doing a project for which I have to use Poser 7. Anyway, I installed Victoria 4.2, and she installed fine, no problems. I installed the morph++, there are appeared to be no problems. They show in Poser 7, I click on the icon for morphs++, I get a message that they're loading, but when I click on any of them, nothing happens to V4. I tried re-initialzing the bat files and still nothing. is there anything else I can do to get the morphs++ working in Poser 7? Any info appreciated, thanks.
You did install the morphs++ in the same runtime as you installed V4?
And are you using the parameter dials to apply the strength of the morphs?
Thanks for your reply. Ok, here's the folder hierarchy of how the morphs++ were installed.
The Victoria 4.2 folder
And here is the next folder in line
And the folder where the morphs++ reside
Those files inject the morphs -- after that you need to go to the Parameters tab to dial the strength of the morph.
So below is a diagram of what I'm doing in order to invoke the morphs++ in Poser. I click on the face on the right hand most side, and I don't get any results. Is there anything else I should be doing. As you can see form the dial and eveyrthing else, the morphs++ should be working. Is there anything I"m missing. Thanks for your help.
Hi Fix, thanks for your help. Here are the parameters that are showing on the dial. I'm clicking on the face that says "afraid" and these are all the parameters that it's showing. Is there somewhere else I should be looking? Thanks again.
The section above that, where it says "Morphs | Expressions" will have the facial expression morphs.
Yes, I've seen those, and they definitely work, I've changed the different faces, but what I'm trying to do is to click on the expressions that I posted on the right hand side and have those change Vicky's face. How can I get that to work? Any info appreciated thanks.
The injection won't auto-dial the strength for you. It wasn't made that way.
Use it like this
thanks chohole, I had no idea that's how it worked. I thought you just clicked and it changed. I will experiment with that tonite.
thanks Vaskania, I thought you just clicked and it changed.
