Layered Image Editor - Daz 4.6
So, I'm trying to open the layered image editor for the skin of genesis (2 but I think I tried it with both)... However, when I open the editor up, nothing shows and I can't seem to work out how to open it so that the skin shows as one of the layers so I can add an additional layer on top.
Is there something I'm doing wrong or any help will be greatly appreciated. Thanks.
Never mind... I think I found it, but if you want to contribute all help will still be appreciated. Thanks.
Surfaces Tab and then Right Click any Surface Channel that loads a Image file. The Little BOX of the image. The Last item in the Drop down Menu will be the LIE and will then open with that texture from the channel of the selected surface ready for you to work with.
I am a newbie here. And you said you the problem was solved. Could you please explain the solution here?
You load the Texture on the figure that you will use First, then you open the LIE from that surface tab in the Surfaces. The skin texture will then be in LIE for you ready for you to add a layer to.
