Cracks
konkon Posts: 389
I keep getting these lines when ever I render my character.
  • SzarkSzark Posts: 10,634
    what is your Advanced Render settings Shading Rate set to 1.00? if so drop to 0.50 - 0.20
  • konkon Posts: 389
    edited March 2014
    nope didn't change a thing
    Post edited by kon on
    What shader?
    And what are the values for displacement strength, min/max and are there any displacement maps being used?
  • konkon Posts: 389
    every thing is as it was when downloaded nothing was changed its just v4 skin mat on genesis
    did you look at this setting yet? But MJC has a point no matter if it loads at a default setting but I still think it is your shading rate.
  • konkon Posts: 389
    I tried nothing changed
    Post a screenshot of the Surface settings for the head.
    edited March 2014
    This is nothing to do with the downloaded and installed character. Shading Rate is a render setting — the default value when you install the program (not the character) is suitable for preview or test renders, but if you want a final quality render of anything, a typical value is 0.2 or 0.1.
    Post edited by SpottedKitty on
  • konkon Posts: 389
    I deleted the character starting over from scratch thank you all anyway.
    Did it have displacement maps?. I ran in to a similar problem with special effect displacement maps that where in jpg format. Because of the compression artifacts with jpg areas that where meant to be solid black were not. I had to fix the black area in a paint program and re-save as tiff format.
