Tier 1 is back
Taoz
I finished MM Tier 1, and at that time it shifted to Tier2 / $2 each, but now it says Tier 1 / $1 each again? Anyone else seeing this?
Taoz
yep, they gave the coupies, now we start over.
sigh
didn't have enough punches for girl6 or the horsey.
It is, but it still says Tier 1.
Not still, but again it says Tier 1. Week 2 started with new tiers. So you can get another 4 tiers this week, which means another $50 coupon max.
Hence the 'Madness' part of the title...I'm not sure that ANYONE knows, exactly, how it all works...the last person who mostly did, is now relegated to being featured in some of Jack T's renders...for some of his products.
Well right after I completed Tier 1 it said Tier 2 / $2 Each. Now it's saying Tier 1 / $1 Each again. That's wrong.
Each week is a new set of tiers. On Monday you get a coupon code for the previous week and the punches reset.
Ah, OK. 4 tiers of 5 punches a week. I thought it was 1 tier a week.
Yep - you can get up to 20 punches each week.
(I got four punches last week. No coupon for me, and I'm set back to zero just like everyone else.)
With four punches you should have a $4 coupon - the tiers affect what each punch is worth, but they don't ahve to be completed to get a reward.
Each punch is worth $1. So, If you got 4 punches you should have a coupon code for $4.00 off a DAZ original. You don't have to complete the tier to get a coupon.
I only had four punches but I got a code for $4.00 off.
Charlie
Look to the right of the banner at the top of the store
Well, there's something wrong, because I didn't get a coupon.
Unless that black box that's showing at the top of my page is a coupon code.
EDIT: No, that isn't a coupon. I copied and pasted the box and the text on either side of it:
There isn't even a space after "Use this code", let alone a code.
You must have some things blocked then, because you should see this across the top
I've looked with IE and SeaMonkey, with the same display. I've never seen a banner that looks like that.
Maybe it's an WinXP thing?
(And I have to go to a meeting...)
Odds are it's MM-WEEK1-4OFF for you.
(Logs in on my BlackBerry) Yes, it is... Thanks for the help.
EDIT: Not much on the DO list for between $3 and $4 that I don't already have ... A-ha! 24 Troll Poses! Maybe I'll actually use Predatron's Troll if I get those.
I think those are for the old DAZ Troll, not Predatron's.
They are for the old DAZ Troll, but (according to the product page) Pedratron made that one, too.
It is an IE8 thing. IE8 is too old to handle the code (HTML 5 etc.) on many sites correctly these days. Use FireFox or Chrome or whatever updated browsers there are, in XP (IE9 and higher won't work in XP).
