Smart Props G8M to G8F
Is there a method to spawn G8M smart props, such as rings and bracelets, in position for G8F? It wears me out having to precisely scale and translate them each time. Thanks in advance!
  • Richard HaseltineRichard Haseltine Posts: 109,077
    You could probably work out the general adjustment values needed for each bone, then write a script that would do the job (check each G8M bone for props, if found unparent in place, adjust transforms, parent in place to the matching bone on G8F).
  • SaintSaint Posts: 64
    That's what I've been doing, manually, was just curious about potential shortcuts in the method. Don't have any experience with scripts here.
  • SevrinSevrin Posts: 6,313
    You're making manual adjustments sound like the easier and faster alternative.
    Meanwhile, it's hard enough to get some accessories to fit properly on the characters they're designed for.
