nore questions about nerd 3d water fall tool
daz 4.6
animate lite
nird 3d - water falls tool
3d universal - sandy bay resort
problem: it seams that when the wf tool is loaded, placed to cover the falls in the senery and sized it goes funky. by that i mean the first frame in animate lite is ok any ajustments that i make they show up in the animation. so through an 8 sec. animation the size of the fall changes as the dose the camers if that is adjusted. I have tryed everthing i can think of. I have tried loading making size adjustments then adding the animation and it goes right back to the same spot where it was when i first loaded it. is there a sequence that adjustments have to be made and i'm i doing it right?
i've spent way to much time and need help.
also there was a link posted of a tutorial on the tool but i cant find it. maybe i can get something from that as well.
thanks in advance.
paul
You need to Do all the Adjustments to the Falls in the First frame. If you change Size later it will Morph UP to that size and then back to Default. You can also KeyFrame as you work to HOLD each change you do. But for Size you set it before you animate and then just vary it some as you go along in your frames or it will morph right back to default after the size change.
Thanks. I believe I set the am lite back to start before any changes. Should I also apply animation before moving and sizing.
Paul
I think so, but It has been a few months sense I worked with it. YOU should have a Tutorial in your DAZ Studio Content folder in the Readme section. The first time I used it I just used the step by step to set it up and then played with it till I got what I liked.
