Adding to Cart…
I like the thumbnail view of the content pane because I can see thumbnails of my scenes.
Me playing with advanced spotlight and a regular point light.
Tests with the volumetric camera. I used the same volumetric settings for both scenes.
The second scene with the unicorn uses 2.5 GB of memory.
I really like the last one. Frog is on verge of entering realm of Teegra and the Unicorn.
Thanks for the comment AtticAnne.
Here is Julie, Dawn and a horse with the lights from Easy Environments grassland. I need to fix the pokethrough with the riding habit's boots.
Memory usage: 2.6 GB. wow
Tip for Poke through, the Polygon Group Editor. Just Hide the poky parts.
Ah, I forgot about hiding parts. Thanks for the tip.
Riding habit uses about 900 MB of memory. Wow.
I've split the first page because it was becoming long.
List of outfits that use a lot of memory:
Estimated virtual private bytes memory usage
When two numbers are on the same line, the second number indicates the amount Daz Studio uses while rendering in 3Delight
Memory usage of female outfits sorted by size:
http://www.daz3d.com/forums/viewreply/507782/
Dawn - 248 MB
Genesis male 1:
Adventurer for Genesis Male - 800 MB
Dark Passion - 780 MB
Effortless cool - 745 MB - 860 MB
Elven Warrior - 730 - ~830 MB
Pharaohs of the Sun - 730 MB
Rock Demon - 900 MB
Wolf King - 830 MB
Genesis female 1:
Kids 4 basic wear - 425 MB
Catgirl nude - 450 MB
17 chic - 850 MB
1950s Casuals ~880 MB
1950s Every day clothes ~730 MB
1950s waitress 830
April showers - 650 - 750
Boudoir Bliss - 660
Day Dreamer - 680 - 750
Defiant - 850 - 950
Dragon Queen - 710 MB - 790 MB 3Delight
Fayre - 900 MB
Elven Dress - 820 MB
Mad nurse - ~ 630 MB
Muse - ~930 MB - 1,000 MB
Onyx - ~850 MB
Pharaohs of the Sun ~780 MB
Pink Ink - 690 MB
Priestess - 730 MB
Riding Habit - 900 MB - 950
Shield maiden - 900
Steampunk Lady blaze- 780 MB
Genesis 2 female with Bree skin:
basic wear - 600 MB
Afternoon Heat - 660 MB
Emotions - 950 MB
Evening Gown - 920 MB - 1,000 MB
Mad Nurse outfit - 750 - 800 MB
Victorian Maid - 925 MB
Genesis 2 male
Adventure outfit - 730 - 850 MB
One more render of Justin in Mall Girl outfit for old times sake.
This scene uses 800 MB. I am using the single core computer with 32 bit windows.
Julie has skin lighting model set to skin. Justin has his skin lighting model set to plastic. I should look for a tank-top for Justin.
One more render of Justin in Mall Girl outfit. Now I will look for some tanktops. lol
I've set his skin lighting model to skin instead of plastic. Next time I should add sub surface scattering... if I remember.
Justin and Julie in lighting from light the way. I found a tank top for Justin.
http://www.daz3d.com/light-the-way
Memory usage: 1.6 GB.
I never did dress Teegra in Pink Ink.
Memory usage: 2.1 GB.
Nice renders, but I swear, poor Justin's gonna be scarred for life. :-P
Not necessarily. It's only a silly cultural belief that only girls get to wear pink and pretty dresses ;)
My 4 year old nephew insisted on wearing a skirt on his b-day.
I'd say bring on the guys in girl's clothes!! (Besides, there really is more girl stuff to wear for our poor models anyway, what choise do we all have? ;) )
thanks for the comments.
I finally found a solution to the poke-through regarding the latex shaders. I need to set the minimum and maximum displacement values to 0.
Andrea and Aaron wearing latex clothes. I've heard of latex paint but not latex clothes. Latex is shiny. I'm going to work on some older scenes now.
This scene uses 850 MB of memory. I dressed Andrea in a bikini because I am running out of memory on my single-core computer. Maybe I'll create a more fancy scene on the other computer.
Justin can wear blue too.
The second scene has the new bus stop in volumetric atmosphere. The bus stop is a bit bright for my tastes.
Both renders use about 2.2 GB of memory. I always forget to adjust the skin settings and the shadow samples before I render the scene.
If Justin likes pink, then let Justin wear pink. If he wants ruby slippers, then the boy should have ruby slippers. No more sexism. Freedom for all.
Justin in his little, black velvet dress. I need more practice posing Jessica dress.
Uber area light
House of Mog Ruith without the tables.
Advance spotlight with gobo shadows.
Genesis basic female has Mara's skin texture.
I added Victoria 4 to one of my old scenes in Daz Studio 3. I then applied Mara's texture to V4. Mara's skin does not look like the skin in the promotional images. lol
This scene took about 8 minutes to render on my single core computer. I used one spotlight and one distant light. I set the shadow samples to 4.
LOL!! Well the Promo's use the best lighting the Artist can set up. So your two light setup just can not match the promo settings. It still looks good to me in your render.
most of my promo lights use 6+ lights
Thanks for the comments.
Let me try uber area light and the SSS version of her skin. The shadows still look fuzzy after I set the shadow samples to 6. I'll use a higher number tomorrow.
I rendered the second image in Luxrender. As usual, I forgot to setup the materials.
Mara with subsurface scattering, without SSS and Cassie with SSS.
I used the lighting that came with Easy Environments oasis.
I just noticed that Cassie's skin looks darker than usual. I'll do some test renders later.
10 year Cassie is cute. The lighting is from Easy Environments Eternal Sands.
Edit: here is the new image. Cassie with subsurface scattering does look darker than Cassie without SSS.
Eternal Sands test. I just discovered that I didn't install all of my animals into the runtime library for Daz Studio 3 and Poser.
I've set the shadow samples to 16 in both scenes.
In the second scene, I applied the elite human sub surface shader to Justin The light in the second scene is supposed to be yellow.
I would have done some fancier renders but it is getting late. Second render has outfits made by Cute 3d.
Nice work there. The little blonde girl looks like she's about to fall out of that dress. It's not exactly designed for girls that "small". :red:
Justin is small too. Young Bree and Justin are wearing the same outfit. The shadows are too harsh for my tastes. I'll play with advance distant light later.
