Hello help please :o
hey guys im wondering if anyone can help me again im rendering this scene but the walls on the right are alot lighter that the ones on the left i dont know why its happening the rest of the room is fine can anyone help thanks :)
light sorce is a single emssive light
  • Richard HaseltineRichard Haseltine Posts: 111,459
    Where is the light? Are you sure there's no HDR conributing?
  • yes sorry i do have HDR also and light is above but invisable
  • FenixPhoenixFenixPhoenix Posts: 3,245
    Check to see if the materials from those walls are the same as the darker walls. It could be that those have 3DL materials rather than iray? Or perhaps they have some translucency set up which would cause light to enter them?
  • iv deleted the walls and tried adding new ones same still happens and nope there iray :s
  • Those are MICK walls, right? Did you try rotating them by 180 degrees, to make sure the normals are facing the right way?
  • hey yes they are and yes i did but it was the same :( even change the roff but still was the same :(
  • so i fixed it in the end i just changed the walls to a plane prim and put the wall texture on it :)
