Can Dformers be used to flatten or smooth mesh?
FauvistFauvist Posts: 2,291
I don't mean smoothing a whole mesh, like a dress, but can a dFormer be used to smooth out small edges or ridges in a mesh.  Like in this image I made, I'd like to smooth out the outer edges of his knees (just because I find the appearance distracting.)
Also, if I'm able to smooth the mesh, can the smoothed mesh be saved?  Or would I have to smooth it every time I open the file.
Also, can anyone recommend a good tutorial for dFormers?
Thanks!
    I would think so, but dFormers are tricky. You might want to check out https://www.daz3d.com/mesh-grabber
  • SixDsSixDs Posts: 2,384
    I agree with Melissa - DFormers require some investment in time in order to use them skillfully, but they can certainly do what you want. Be prepared to spend some time learning how they work and their options. The results may be very specific to the mesh and the pose, so whether saving them for later use will be valuable or not may be questionable.  There are a number of ways that the changes made by the DFormer can be saved, but perhaps the best way is by creating a morph of the DFormed item and saving that. (i.e. apply the DFormer and export the DFormed item as an object, then use Morph loader Pro to import the saved object back into DAZ Studio with the default item loaded. Save the resultant morph slider.)
    edited May 2020
    Just want to add that you can spawn the dFormer to a morph inside DS in the dFormer pane, no need to do the export thing.
    Post edited by Sven Dullah on
  • FauvistFauvist Posts: 2,291
    Considering I've been quarantined in my house for EIGHT weeks,  I may's well give it a try.  I certainly have the time.  I'll have to find some tutorials though.
  • nicsttnicstt Posts: 11,715
    They are too time-consuming and limited imo; I just take whatever I want into blender.
    Is it more time consuming to use the Dformers or to learn Blender and how to move content back and forth between it and DAZ Studio?
  • barbultbarbult Posts: 27,532
    DFormers will only cause you to pull your hair out, if you try to use them on posed characters. You would be much better off to invest the time in the Blender path, in my opinion. Mesh Grabber is an excellent tool, too, and I love it for quick fixes in DS. But it is limited in capability compared to Blender.
  • Richard HaseltineRichard Haseltine Posts: 111,475
    A dFormer witha  weight map is perfectly usable on a posed figure, though the only real way to use it to smooth a mesh would be to scale it down in a direction at right-angles to the surface. I think a better option within DS wold be a Push Modifier with a weight map so that it targeted the areas you wanted to smooth - weight the depressed areas positively and the raised areas negatively and you could probably get somewhere. Still most applications with sculpting tools have some kind of smoothing tool which might well be less fiddly, especially if you are used to using a brush to achieve effects.
    edited May 2020
    I concur with Barbult, Mesh Grabber is a must-have tool.
    Learning to import and export is simple enough; if you want workflow for transferring backwards and forwards I'll be glad to show you mine.
    You can tackle the different results you're after as individual learning experiences. smoothing can be done in a variety of ways, but there are two main methods I use - and usually a combination; either one on its own would work, and then means only one workflow would be investigated at one time.
    There is certainly a learning curve with Blender (i've been using over ten years - could be over 15 or more.), but it is probably at its easiest stage ever; I would still recommend using shortcuts, but they are NOT a requirement in 2.8+ and haven't been for a while.
    Post edited by nicstt on
    I notice there is somthing called the Geometry Editor in the Tools menu.  What does that do?
  • SevrinSevrin Posts: 6,314
    It's used to hide geometry, delete geometry, add material zones.  All kinds of stuff.
  • marblemarble Posts: 7,500
    +1
    I don't know Blender to any proficient extent but sometimes it is fairly easy to learn bits of it for what you need. I think the sculpting tools do the job for me better than dFormers (which I used to use exclusively). Others use the Hexagon bridge but Hexagon isn't stable enough for my liking.
    marble said:
    +1
    I didn't like Hexagon; not enough short cuts for me. I decided to work out how to import/export to Blender.
    Never even bothered with the new version
  • scorpioscorpio Posts: 8,533
    Sorry personally I disagree the inability to rotate mesh grabber limits it usefullness greatly.
  • V3DigitimesV3Digitimes Posts: 3,468
    I agree, in this situation, it would be blender immediatly for me. Export, smooth, import as morph. Because with deformers it seems extremly difficult, if not impossible...
    Do you know if there is a tutorial somewhere that is specifically about exporting figures from DAZ Studio and importing them into Blender, then re-importing the to DAZ Studio?
  • RGcincyRGcincy Posts: 2,864
    This is the way I would go too. You can confine it to the are of interest as you paint the weight right on the character. The push modifier and map will save with the scene, I'm not sure if you can save it with the figure itself.
    I know I have this in a tutorial of my store (Easy Modeling And Morphing With Blender), but honestly I think you should be able to find thread on the forum explaining the principle for free (not tried, but there are probably some).
    IIRC, there is a rotation update coming to the product coming eventually.
