White spots on model face
MuzMelMuzMel Posts: 76
Hey guys. Was just testing out a Capt Marvel render, and there are random white spots on the face. Never happened before with other models. Model base is Gen 3 Alouise. Ive Attached a pic, would appreciate any help on how to fix it
Also if you have similar shorter hair recommends that are more thicker, please let me know!
    I think someone mentioned that if you're using an HDRI for lighting then making it not-visible in your render settings can fix that white spots problem.
  • WonderlandWonderland Posts: 7,133
    edited May 2020
    That looks like shine that hasn't fully rendered yet to me. Have you tried letting it complete the render?
    Post edited by Wonderland on
  • FauvistFauvist Posts: 2,219
    It looks to me like "metal flakes".
  • MuzMelMuzMel Posts: 76
    Ah this was stopped at 80%. The more the render went on, the worse it got.
    Any idea on what setting to adjust? I tried playing around with it on surface tab, didnt change.
    Hmm I see. Will give it a try. Any idea where I can find that seting?
  • TaozTaoz Posts: 10,262
    edited May 2020
    Render Settings > Environment > Draw Dome > Off
    Post edited by Taoz on
    Oh I see, yes I tried that, didn't work
    Where did you get the character from?  Not in the DAZ store.
  • SevrinSevrin Posts: 6,313
    Not a fix in all cases, but maybe check to see if Spectral Rendering is on.  That can cause problems in some lighting situations.
    She used to be!
    Did not work unfortunately
    Had it right. Setting "Mettalic Flakes Weight" and "Top Coat Weight" and "Glossy Layered Weight" to 0, the white spots are completely gone. I will play around with these settings till I can find one where the skin still has some sheen, but no random white spots
    edited May 2020
    MuzMel said:
    She used to be!
    I use Metallic flakes to make glossy droplets that look like natural sweat or perspiration on skin.  It looks EXACTLY like sweat under a bright HDRI beach scene.  "Sheen" may be a different look accomplished a different way because  most often a sheen on skin is just the natural oils present on skin.  Also, on a real human, if you exfoliate the skin on the face to remove all the dead skin flakes, you get another kind of shine (which I don't know how to duplicate).
    Post edited by Fauvist on
