error in deformed abdomen how to fix it? (Fixed)
shona_nqnshona_nqn Posts: 34
edited May 2020 in New Users
was using the base genesis 8 model without morphs to pose and I ran into this problem ... just use base genesis without morphs ...reinstall genesis 8 base and it doesn't work .. try a character and it's the same error ...
I can not upload the image .. but basically the abdomen is going forward, the arms and legs are fine apparently .. it is only the abdomen and chest that are out of place ...
Edit: I fixed it by deleting the morph I added last time
Post edited by shona_nqn on
  • Richard HaseltineRichard Haseltine Posts: 109,129
    Check the Currently Used group in the parameters pane, probably with Show Hidden Properties on in the pane's option menu (the lined button in the top corner or right-click the tab, in the preferences sub-menu) I think this is a corrective morph from an add-on that is applying always instead of only when needed.
  • SO frustrating! So many times I come here looking for answers, and threads go unresolved with nobody replying, or in this case, a solution is found with no details given! What the heck was the morph causing this issue!
