View Translate and DS3A...
joegerardijoegerardi Posts: 226
Any way to turn it off? It's a real PITA to me.
Thanks,
..Joe
  • Richard HaseltineRichard Haseltine Posts: 108,799
    You mean the tool widget that lets you drag on controls in the viewport? I don't think so, but you won't get one with the Node Selection tool.
  • MattymanxMattymanx Posts: 6,998
    I will be honest Joe, I am not sure what you are reffering too.
  • joegerardijoegerardi Posts: 226
    View translate allows you to move parts of characters when you're in the standard window. (NOT active pose.) Or, if you click on a part of a figure and don't let go of the mouse quickly enough, it destroys your whole pose until you go undo what you just did, hence the reason I wast to turn it off.
    ..Joe
    Ah, Inverse Kinematics. There is a command to turn it off, but I can't recall where it lives - possibly the option menu for the rotate control in the top corner of the viewport (the sphere surrounded by circles).
    Thanks. I call it that because in Edit> Undo it states "Undo View Translate."
    ..Joe
  • JaderailJaderail Posts: 0
    You have the Translate tool as your active Tool. Pick another tool from your TOOLS Menu.
