Blue background
I use Daz3d to make renders of characters only. I used to have a nice transparent background when I rendered. I must have done something wrong but now all my renders have a light blue background (the color of my viewport background).
How do I get it back to transparent?
Change the image that you save your render to as PNG, that has a transparency.
It must be set to JPG at the moment.
Actually no it is set at png.
Save the image file, and then look at it. It should then be transparent, mine shows a blue background as well in the Preview window, but not when I load it into windows Photo Viewer. I see you are on a Mac, but it must have a similar viewer.
Thanks Addict,
You are right. It is transparent if I open it in pixelmator.
Glad it works for you.
The reason for the Smiley is because I am JimmyC_2009, Addict is what the forum software calls me because I have so many posts, in the same way that it calls anyone with under 100 posts as a New Member, even if they have been here for years. You are not the first one to make that mistake.
Best wishes
JimmyC
