Wall removal
I am working in a scene with The Office (https://www.daz3d.com/the-home-office) - love the asset, use it for a core set of scenes, but I've run into a problem where I want to pull down one wall, but the asset only lets me pull the all down or none of them.
I was going to set up a vignette to mirror the scene by basically reconstructing it with other assets that did not have the wall, but wanted to stop by here and see if there is an easier way to knock out one wall via some other means.
Just to be clear - there does not seem to be a way to adjust the surface of the one wall – all the walls are one object and surround the entire room (as opposed to being separate walls that can be manipulated independently).
Thanks!
If you really want to remove it you could use the geometry editor to either create a new surface or directly hide the polygons for the wall.
@pazlen
An Iray Section Plane may do what you want.
https://www.youtube.com/watch?v=GCJfIlk-4Yo
