shadow not shown on a certain props
hi all
i have an issue with shadow:
when i use medieval tavern and some light (prefab or not) i dont have shadown on ground, and on table,
http://www.daz3d.com/medieval-tavern
in flags in parameters i have receive shadows on yes
anybody have hints?
https://plus.google.com/u/0/photos/yourphotos?pid=5985510859414540786&oid=109419116686653458295
thanks
Neva
first check to make sure the lights are casting shadows, select a light and in the Parameters Pane (presuming you are using Daz Studio) and check to make sure shadows are turned on. There are off by default.
just for to know if i understrood lights:
i have to make a light with shadow on shadow map and one with no shadow? on just one with shadow on shadow map?
For shadows always use Ray Traced, the Deep Shadow Maps have a render error in the Render engine. That is a error the maker of 3Delight knows of and can not be fixed by DAZ 3D. So for Shadows just use one light unless you need more with Shadows set to Ray Traced.
