Solved: I made a reinstall of DAZ 4 Studio Pro with 32 bit instead of 64 bit but something is not ok
Alfhak712Alfhak712 Posts: 94
edited July 2012 in New Users
I had an issue earlier with the 64 bit version and got some things to work with the 32 bit instead as I wanted!
I think I have installed everything as it should correct but things who earlier was in the "Smart Content" tab on the left
are gone now! Default things and also addon! I can find the things in the "Content Library" to the righ.
It looks like I can find everything installed in the "Content Library" but they refuse to show up in the "Smart Content"
Another things that also have happend after reinstall things is I got lots of empty items missing in "Smart Contents"
that I have uninstalled before I reinstall again! Missing items!
Here is the tree for my DAZ install!
D:\Users\Alf\Documents\DAZ 3D\Studio\My Library
D:\Program\DAZ 3D\Content Management Service
D:\Program Files (x86)\DAZ\Studio
D:\Program Files (x86)\DAZ 3D\DAZStudio4
Here are two images from the Content Library and Smart Content!
Let me know what I made wrong and how to fix it!
Thanks!
Post edited by Alfhak712 on
  • edited December 1969
    What problems did you have with the 64? I'm trying to decide which to use. I spent a week trying to get content installed. Gave up and unistalled everything. Starting from scratch.
  • Alfhak712Alfhak712 Posts: 94
    Check this thread! The issue was with creating an avi file for movies!
    http://www.daz3d.com/forums/discussion/4235/
  • SzarkSzark Posts: 10,634
    edited July 2012
    Time to "Reset Database" and "Re-import Metadata"
    With the Content Library Pane open (not Smart Content) go to the Options Box as pictured below. Reset the Database first and close Daz Studio, open and then re-import Metadata. Hopefuly all should be well after that. :)
    301 x 219 - 78K
    647 x 1018 - 202K
    Post edited by Szark on
    Oh and another thing just out of interest have you got any content that is installed into Program Files. If so it would be better to reinstall again this time making sure no content goes into Program files directory of you Hard Drive..
    Thanks for the advice on Reset the Database and Re-Import Metadata!
    The only thing that is installed in program files are the main program
    and the other I have no idea what it is! as shown below!
    D:\Program Files (x86)\DAZ\Studio; No clue what this is and why it get it own folder!
    All content are installes in the following way!
    Good Just wanted to make sure so you don't have more issues with content.
    Please let us know how you get on with the tips I have given. If you solve the issue can you edit your title and add the word Solved please. Cheers.
    Thanks for your kind help!
    The problem is solved now!
    Thumbs up!
    Sweet thanks for the that, Glad you got things sorted. :)
