will TexturePaintHelper Loader Plugin work with DS 4.6?
TSasha Smith
Will TexturePaintHelper Loader Plugin work in DS 4.6? or is it only for DS 3 and earlier? I want to make sure before I get it.
AFAIK, it has not been updated for any version of DS4. DS3/3A will run a system that also has DS4 installed. Just don't try running them at the same time. I run into this all the time with Dreamlight plugins.
You should even be able to run them at the same time, since their settings and resources are in separate locations (as long as they aren't sharing a temp folder).
so I can run DS3 and DS4 and DS5 all at the same time?
If you have a good enough computer and a time machine to get DS5
Some doctor stole my time machine, but I did not catch his name.
If you have less than 4 GB of RAMm maybe not...4.6 is a RAM hungry beast, so at less than 4 GB you will quickly run out. 4 GB is no guarantee that they will both run at the same time, but it isn't very likely to work with less than that.
can someone explain to me more about what this plugin does? it is not entirely clear to me from the description
is this some type of paint program accessible within daz
can you import other textures in as well and overlay them on the textures exported from daz
etc... not sure what it does so not sure what all questions I should ask
I have 8 or 9 gigs of ram.
The loader plugin allows you to access this app
http://www.daz3d.com/texturepainthelper
inside DAZ Studio. You must own both the full application and the plugin. However, the plugin works in DS2.2 and DS3. It does not work in the current version of DS.
ok, I see thanks
