SOLVED - Reflections furniture - some items rendering with washed out textures
ShaneWSmith
Hi all,
There's probably something really obvious I'm overlooking, but this test render I've done of a scene I put together is washing out several of the figures. All the washed out bits seem to be wooden parts of the Reflections Furniture set, although not all items in this set seem to be affected.
I really have no idea how to troubleshoot something like this, so any advice you can give would be greatly appreciated.
Thanks!
SOLVED: Turns out the ambience in the Materials page needed to be set to zero.
Post edited by ShaneWSmith on
My first guess is that these surface have reflection maps applied. Personally I removed these and use real reflections though it will increase render times a lot. But adjusting the reflection settings might help
Just a thought: are you in DAZ Studio? And if so, are you using the DS versions rather than the Poser MATs for these?
To me that looks like the typical overdriven Ambient common with Poser materials used in DS...
Sorry, should have said before: I'm using Poser Pro 2014.
Is anyone able to load up these items and fire off a quick render to see if they get the same result?
@Szark, I'm not in front of my rendering computer at the moment, but from memory, these surfaces had nothing at all under reflection in the Materials tab, whereas the parts of the render that worked properly did. How do I add reflections to these surfaces?
Edit: SOLVED. Turns out ambience (Materials page) needed to be set to zero (was 0.1454545).
Sorry no idea about Poser and I haven't yet installed Poser 8 yet on my new rig but I presume you would need to go in to the Material Room and plug in the reflection node.
Ambient would have been my second choice....honest ok not really, not on top of my game at the moment.
This has been updated for this issue.
