converting head from Genesis to Genesis 3
in The Commons
I love this beautiful head for Genesis 1, and I tried to convert to Genesis 3 on my own by just adding a extension to the neck to connect to G3F neck for geo-graft, and everything went all ok. However, the morphs went all AWRY, it went so distorted on pretty much of the entire figure when I move the slider on any morph. When I loaded in the Geo-graft, I used Transfer Utility to transfer the morphs from the original figure from Genesis to the new geograft on Genesis 3.
if you can compare to Genesis and Genesis 3 (see attachment)
Hmm, to make Genesis 1 head into a geograft for Genesis 3???
You made a 'clothing item' of Genesis 1 head attached to some new geometry to add it onto Genesis 3, fixing it up so that the Genesis 3 head would hide when the Genesis 1 head geograft was applied, and then ??? you tried to transfer the morphs from Genesis to the geograft on Genesis 3???
No I don't think that would work.
The concept is that the existing morphs for Genesis 3 may or not {because heads are not bodies} apply somewhat to the geograft attachments.
When making the Genesis Head which is to become the geograft I would suggest morphing it before cutting out the mesh.
Silly question, if you like the Genesis character why are you wanting to change it over to Genesis 3. Just curious. It might be easier to remake the morphs for Genesis 3 in the usual manner, then the eyes and everything will work as they should for Genesis 3 [hopefully].
