Render Problem
Why this black marks on his forehead is there when I render it? I found that when I delete his hair everything seems fine. Its problem when I add this particular hair. I am using steven hair for genesis 8 - http://www.daz3d.com/steven-hair-for-genesis-3-and-genesis-8
any solutions to this, mates?
  • SevrinSevrin Posts: 6,313
    You will need to make a small adjustment to the head size in your parameters for the hair. 1 or 2% should do it.
  • LenioTGLenioTG Posts: 2,118
    Yes, adjust the hair parameters.
    You can also try changing the optimization mode in the render settings pane.
  • jmtbankjmtbank Posts: 187
    There is a morph within the Sven hair to increase "forhead depth".
    Whilst the Sven hair needs a lot of 'cap' size adjustments to stop those render squiggles it comes with the morphs to fix it.  With other hairs, they don't always come with fix morphs.  For those you would need a body morph pack with cranium size adjustments, adjust a % on the character to 'pass-on' to the hair to adjust more.
    I don't always know if products with fix morphs is a good thing as it increases load times, but some products really need them.  And for some people purchasing products may not have all the body morph stuff yet.
