Duplicate formulas found in files.
Please, do you know, how try what and where is duplicate mistake. I have problem only with loading Genesis 8 male in studio.
Thx
  • Richard HaseltineRichard Haseltine Posts: 111,482
    edited April 2020
    It usually means that two products you have installed use the same name for their shape, and have a link to another property with a common name. First I would check to see that none of your purchased content has an update available, these things are usually fixed quite quickly, but of course it may be a freebie or soemthign of your own creation. If you can't deal with it through product updates then go to Help>Troubleshooting>View Log File, jump to the end, and search backwards for "duplicate" - that should fine ne or more lines with the fuller details, which will tell you the name of the problem morph(s) and the location of one of each pair.
