Adding to Cart…
I would break up the maze into (relatively) simple blocks, and then assemble it from those blocks. There are settings so you can make blocks with open/blank ends, but frankly I wouldn't bother, keep it simple.
You can make a block of any length, just keep in mind that if you increase the scale of a dimension of the block, you have to decrease the scale of the underlying leaves dhair.
So if block Y is 400%, make the leaves Y scale 25%. Or they get distorted.
Thanks Oso3D!
