[Released] dForce Thicket Shapes
2»
  • Oso3DOso3D Posts: 15,090
    I would break up the maze into (relatively) simple blocks, and then assemble it from those blocks. There are settings so you can make blocks with open/blank ends, but frankly I wouldn't bother, keep it simple.
    You can make a block of any length, just keep in mind that if you increase the scale of a dimension of the block, you have to decrease the scale of the underlying leaves dhair.
    So if block Y is 400%, make the leaves Y scale 25%. Or they get distorted.
  • JeremyDJeremyD Posts: 265
    Thanks Oso3D!
