How can I morph or change the polygon size of an object?
Hi, ive tried to attach an example of the help I need. I basically have a soldiers hat but i'd like to edit it to look slightly different.
I have A, B and C questions if this makes sense.
A. I would like to be able to fill in an area where polygons are missing so it smooths of the top of the helmet.
B. The hat and strap are a grouped object. I can select the strap as a surface. Id like to be able to take the strap and scale it to a slightly different size as well as morph the top of it.
C. The helmet needs to have the front section altered. I would like to be able to grab the front polygons and move them or morph them into a diffent shape justy on the front. The lower section of the example is roughy what im trying to achieve.
Can anyone help me on this please? Thank you.
Jase
  • Richard HaseltineRichard Haseltine Posts: 108,598
    A morph cannot add or remove plygons, it can only move the existing vertices. A morph is just a set of changes in position - if you leave areas of the model unchnaged the morph will have no effect on them.
