How can I transform an object to a figure and animate it?
I made a character with spheres and cylinders in DAZ studio.
I want to learn how to animate my character! Please help and teach me this!
I have attached my character in .DUF file here below
  • Richard HaseltineRichard Haseltine Posts: 109,523
    A series of parented props, if that is what you have made, isn't truly a figure. You can pose it if the props are parented in a hierarchy, but other things like morphs and pose controls that affect multiple parts, won't work. You could turn the model into a figure, by exporting as OBJ and then importing that into the Figure Setup pane, but it depends on your ultimate goal.
  • Yeah, but when I export it to an .OBJ file the dimensions change
  • CriosCrios Posts: 3,003
    When export in OBJ you must set DAZ scale at 100%,
    The import and export settings must be inverse of each other - 100% is easiest but not mandatory.
