NBM for v4 help!
I recently bought the following product
http://www.daz3d.com/nbm-for-v4
But after installation, selecting V4 and clicking the INJ file for the morphs nothing seems to have happened, I can't find any extra dials or settings
Can anyone help me figure out what I'm doing wrong?
How did you install them?
It/they came as a file which installs itself when you double click on it, I followed the prompt to initialize the morphs, let the installation finished, then opened DAZ
Here is the Question. Did you have the Installer put the files into the same content folder (My Library or My DAZ 3D Library) that you have the V4 figure in? If not they will not work.
The installer put the files in My Library, the same place all my other content is in.
Do you mean I should maybe have the installer put the files in the actual V4 folder?
I'm a little confused
No, just the Same content folder, which it seems you have done, so that is not the issue. I was just checking.
ok, so what is the issue preventing the morphs showing up in the parameters? I'm selecting v4, then clicking in the INJ file in the content library, I see a progress bar for a few seconds, it reaches 100% then disappears, I then go back into parameters, but no new options have appeared?
There is a similar topic where this item is briefly discussed http://www.daz3d.com/forums/discussion/33682/ but I didnt see a solution posted there
Have you Seclected The CHEST area of the Figure in parameters? They only Apply to the Breast not to the full mesh zones.
I selected the chest of v4, then injected the morphs, same result they don't show up
You inject the Morphs with V4 selected, then you select the V4 chest and they SHOULD be in the Morphs list in Parameters like this....
After experimenting a little it turns out the NBM morphs cannot be used with a V4.2 that has a product called Lali's Bits installed.
They load just fine onto my basic v4.2, but my V4.2 with Lali's Bits installed? Nope
Thats what the problem was/is
Thanks for the help Jaderail
In that case you should also know the NBM will not work on the Perfect V4 if all the Perfect morphs are injected as well. I use it some myself.
I only have Lali's Bits for Poser .... for me both NBM and NGM can be injected and will work okay with a Lali V4 cr2 (but she already has similar morphs built in). For me NBM does sometimes gets stuck/freezes but I just use the included NBM reset poses provided and then you can apply a different movement. I don't have the DAZ version of Lali's bits. but I have heard that is more complicated to install and may have more limitations with other products.
