Dforce wind node Hair blowing
cosmicdawnseries
hey guys i want make a animation using dforce windnode to create a hair blowing effect like this ? has anyone got any advice or know what i can do to create the effect please thank you :)
iv tried but i cant do it :(
thanks and i hope your all well <3
link = https://www.google.com/search?q=3d+hair+blowing+in+the+wind+gif&rlz=1C1CHBF_enGB863GB863&sxsrf=ALeKk02ybU1tRywzw5YYNy0MTyO2Tq4VRA:1586664091083&source=lnms&tbm=isch&sa=X&ved=2ahUKEwj2kpusgOLoAhXOXRUIHUV2BkYQ_AUoAXoECAwQAw&biw=1280&bih=561#imgrc=M46SP-x2p9TrEM
The simplest method is to move(translate and/or rotate) the wind node at various points through out the animation sequence.
You'll have to play around with the position, possibly the number, and all of the settings of wind node(s) to achieve the desired result.
Also, be sure that the Duration, is set to Animation.
Sorry for the long reply working a lot Sx ill
try it tonight thanks for reply ????
it worked thanks ^^
