Problem with Daz visualization
KarasuKarasu Posts: 5
edited April 2020 in New Users
hi, this is the first time i use daz, and i have a problem that you can see in the image. it happens as soon as I insert a new element in the scene, and each time I have to save reload. What do you think it can depend on? (when I render, the image comes out correct even if it is displayed in this way)
Post edited by Chohole on
  • Richard HaseltineRichard Haseltine Posts: 108,459
    Does your computer have an Intel GPU on the CPU and a stand-alone GPU by AMD or nVidia? If so make sure that DS is using the latter for display - right-click on the desktop and select the nVidia or Catalyst Control Panel to do so. It may also be a matter of needing to update the driver for your video chip.
  • Saw an image similar to that someplace on the 'Net and the solution given was to update the drivers.
  • KarasuKarasu Posts: 5
    edited April 2020
    Yes, actually DAZ used the Intel GPU and not the Nvidia, I have changed the settings and for now I have done a test. It seems to run well.
