Jagged Pix Venus
Anki
I'm trying out Pixluna's Venus 500 (https://www.daz3d.com/pix-venus500-for-genesis-8-female) which looks perfect on the product's page, but coming up with these horrific jagged edges. Am I missing something ? I couldn't find any instructions.
Post edited by Anki on
Are you using the correct preset (3Delight or Iray) for your current render engine?
Look closer at the promo images, they all have this issue.
You might try turning off limits on the Subd and cranking that up past 5(default max) and it may clear it up more.
Be aware that you will need a significant amount of system ram. 16GB won't cut it.
Other than that, you''ll need to edit all the maps in a photo editor.
Thanks for explaining. I'm sadly limited to 16GB.
I guess I'll crank it up to SubD 5 and then I'll smooth it over in photoshop. :)
