Scenes don't work as intended.
Hi, Does anyone have any idea why scenes that work in the previous version of DS load as big grey boxes in the current version? Is it something that I'm doing wrong? Any help greatly appreciated.
Its not reading the Data for some reason. Check to be sure you Content folder paths are still correct. They should be as the Update reads your old settings file. But that is a known cause of the boxes, the content not seen by DS properly.
One of the common causes of that is nested content folders. Another common one is not having the data directory visible to Studio.
I was thinking it might be the Nesting, but it should have popped up in the old version of DAZ Studio as well if that was the cause, to my way of thinking. I still think the Data folder is not seen.
Of Course Which version they just upgraded FROM might play into it.
If it is Data then reloading all the items in a new scene and saving it should reset the data files, don't worry about position, just load and save, exit, reopen the old scene. It has worked for me in the last version of DS as I have a new rig and my content path has changed. DUF files all work as they should...I love DUF
