Square panels that shouldn't be
CMKook-24601CMKook-24601 Posts: 200
so I am trying to figure out why the square paneling this is going on in this pic... I am using uber lighting along with spot lights going down the hall and one linear point light.
  • JaderailJaderail Posts: 0
    Check to be sure you do not have a second version of the prop loaded. Looks like two ceilings rendering at same time. That is my first guess. Without more info it is all I have right now.
    My first guess is you have your Uber lighting set to a low number of samples. The more samples available, the more detailed the lighting results will be, and the less visible blotches. Check your sample rates on the lights and if they seem fairly low, increase them appropriately.
  • CMKook-24601CMKook-24601 Posts: 200
    edited February 2014
    that would make sense
    Post edited by CMKook-24601 on
