Planet Earth HD Materials Issue
TTGeek
I have Planet Earth HD by ThePhilosopher and have a problem with the materials showing up on the inside of the sphere, not the outside surface as expected. Can someone give me a clue as to how to correct this issue.
Regards
unless you are referring to it doing this when rendering, what you are seeing is perfectly normal.
The viewport isnt going to show you what the render will look like, unless you turn on iray preview mode.
Textures will look weird, maybe even completly borked, but when you render it clears up.
Attached a quick example.
