DAZ Studio Environment Shaders
Are these 3DL Only
  • McGyverMcGyver Posts: 7,097
    They are pretty old, so probably... I think I picked them up years before iRay.
  • SevrinSevrin Posts: 6,314
    https://www.daz3d.com/daz-studio-environment-shaders These?  They're from before Iray, so yeah.
  • Thanks. I need some 3DL shaders.
  • NorthOf45NorthOf45 Posts: 5,760
    If you follow the shortcuts at the top of the main page (Resources and Add-ons, then Shaders) and sort by New Arrivals, the 3DL shaders will be at the bottom of the list. When Iray shaders started being released, they were very vocal about it, so you will know if it supports 3DL and/or Iray around the transition. Newer releases at the top of the list are most likely to be Iray only, but they would say if they support 3DL, too.
    Another way to tell is by looking at the SKU number on the store page. The first version of DAZ|Studio that supported Iray came out when new store products had an SKU of about 21000. Anything below that is definitely for 3Delight. Items above that could go either way, although Iray items were a lot more common above an SKU of about 23000.
