How can I install Michael 4 Base
Hi, I noob in Daz and I obtain the Michael 4.2 Base (very glad) and I can´t find it in the install section of Daz studio
Is trought the Daz install Manager I guess? if is it, how is the process? Thank you.
Hello!
Michael 4 installs to a Poser directory format so you will need to go into your Content Library Pane and right click on "Poser Formats" on the left side and select "Add a Runtime Directory" then point it to your install location that DIM is using. Once you have selected the directory and linked it into the Content Library Pane he will be located in "Figures/DAZ People", his material and morph options are in "Pose/DAZ's Michael 4". He does come with default sample resolution materials for Daz Studio they are found “People/Michael 4/Materials/M4 Sample-Res”.
Elli
Michael 4 and Victoria 4 can't be installed via Connect (install tab in DS) due to the system they use for morphs. That's true for the base figures and their morph packs, but clothes, hair, accessories and most characters can be installed with Connect.
This took me way too long to figure out when I first started using DS.
Thanks Elli. That´s really works. Also I find the Install Manger way also works. Now I can play around whit the products of Michael 4.
(I post two times the same comment, sorry x that)
Thanks Elli. That´s really works. Also I find the way of Install manager also works (reading the docs) . Now I can play around whit the products of Michael 4
