point at
I have googled for solution to a sertain problem, but I dont find anyone trying to salve same problem.
I want to animate the point at function.
Lets say I want a person to walk along a path, look at one person with the point at function, and during the animation chang the point at to go smootly to be at the camera.
Is it possible to make this, without using null's?
  • Richard HaseltineRichard Haseltine Posts: 108,982
    Not as far as I know.
  • Matt_CastleMatt_Castle Posts: 3,055
    Is there a reason you need to do it without using nulls?
    Unless you've got a good reason to not use nulls, that's going to be the easiest way to do so.
