Rendering Wolf 2.0 Fur Texture Help
Hello, I was hoping to get some help. I am trying to render a scene with some wolves from the Wolf 2.0 set. I got the posed and everything, but I can't get the fur to show up on the wolves. Some help would be very much appreciated.
I have the render included so you guys can see what I mean.
  • scorpioscorpio Posts: 8,533
    Are you rendering in 3dl or Iray.
    If Iray did you convert the fur?
    I am rendering with the NVIDIA Iray render with the IRAY advance render settings preset. How do I convert the fur?
  • LeanaLeana Posts: 12,954
    When using LAHM fur with Iray you have two options:
    • You have the Catalyzer plugin and there's a Catalyzer version of the fur (there's one for wolf 2): in this case use that version and use the render button in the Catalyzer window to render.
    • You don't have the plugin, or there's no Catalyzer version: you will need to export the LAMH fur as obj, then import that obj back in your scene to replace the LAMH fur, and then render.
