Body morphs
I assumed when I bought the pro pack of both male and female. That it would come with full body morphs. And it probably does I just cant figure out where the female ones are.
I created a good looking guy. Now I am trying to create a woman but the breast controls are not what I would expect. Increasing breast size gives her cone boobs. Where are the shape tools for that?
I looked at getting the female morph but it says I already have it.
Working with Gen 2.
Second question. How do I save my newly created models as presets or templates to come back to and not have to do them all over again.
Thanks in advance.
I looked for hours... After I post this I found it in 2 min.
To answer the last question first...you can save them as Character presets, if you've set up textures to go with them, Shape presets, if all you want is the shape, or Scene subsets if you want them fully clothed and ready to go...all those are under File > Save As...
For the morphs...they should be in the Parameters for that figure. That means you need to select Genesis 2 Female in the scene and then under Actor there should be morphs...also some might be found in the Shaping pane...
thanks
That helped.
Alternatively, I've always found it much easier and faster to use the Content Tab directly for all my saving of scenes and presets. Just navigate to the folder you want to use (or create a new one) and click the little "+" at the bottom, then select which type of save you want to do.
Note that this should be done in the Content Library tab, NOT the Smart Content tab.
